Charrlie_S
Is the two wire plug from the distributer pluged into the harness?Confused what is the question?
I don't know "them all" one of the guys on here used to put together connector kits for 6 or 8 pin so yeh, they can be made to work. One advantage of the "more than 4" is they use weatherproof connectors.8 pin? Why that one? I'd go with the plain old 4 pin hei. What's better about the 8 pin version? From what I remember there will be 4 unused pins, will it even work that way?
I've left that thing off before....Stupid question. Is the two wire plug from the distributer connected to the harness? If yes, make sure the battery is charged up, recheck the voltage at the coil + (it should be more then 5 volts with ign sw on, but not cranking). If voltage is around 8 volts (or higher), connect test light to coil (-), and crank engine. Test light should "blink" on and off. That will tell you if the dist is sending a signal to the module and the module to the coil. If the test light does not blink, it could be a bad module, or bad pickup in the dist.
LOL. Progress at any cost................
