Mattax
Just the facts, ma'am
That might explain it.Testing for ohms, volts and current
No.We will do another test possibly tomorrow and we will crank the car and take mesurements at the coil and ballast
No.
To trace the problem hot, begin as close to the power source as practical.
Select volts and probe the junction that should have power with the key in whichever position you are checking.
The problem currently is when the key is in run. So my suggestion is put the key in run, back probe the cavity on the bulkhead with the J2 wire.
If that has battery voltage, then check the accessible junctions for the J2 branch wires.
Make sense?
You are holding the Run Circuit. The wires are labled J2 and then a branch letter. This is also called the ignition circuit, or ignition run circuit.
from the Dodge Chassis manual page 164
J2 is cavity N middle connector. Use the bumps (green arrows) to figure out the orientation. If its too difficult to access go to an easier junction first.
16 is wire size, DBL* is dark blue with stripe.
It looks like someone got black spray paint on some of the exposed wires but you'll figure it out.
Lets give these wires their ID and what they do.
The dark blue is J2A, a branch of the Run circuit.
Dark Brown J3 connects to the coil positive. It must be connected to the 0.5 Ohm resistor. With the key off, measure the ohms accross that resistor. If its 5 ohms, its the wrong resistor.
The light blue with yellow, and the green with red wires go to the ECU. The Green with Red (J4) must be connected to the 5 ohm resistor. With the key off, measure the ohms of that resistor. On newer ECUs that wire isn't needed, but since its there you can use an older module or an newer one.
A light blue wire with yellow strip should be J2E, RUN power feed to the ECU.
We see two red wires in this photo.
The one seperate from the harness looks to be larger than 12 gage ? Maybe as large as 8 gage?
Is that bigger wire the one connecting here?
10 gage to the fusible link was standard in '73
I ask because some cars got a heavy duty alternator and battery wiring.
One version came on cars equipped with rear window electric defrosting grids.
Another version was the police/taxi fleet wiring - very rare on A-bodies since most weren't severe use fleet cars. These options used 8 gage wire.
One clue will be if the rear window has a defroster grid.
Another will be if there is a grommet in firewall for those wires.
There's a photo of the firewall grommet feeds here: How rare is electric rear defrost?
and another version here Optional Heavy Duty wiring
Neither should effect your trouble shooting method. But they will change your wiring diagram a little.
Do you think it’s possible that when they guy swapped in the 360, he accidently swapped two of the three bulkhead connectors. The reason I say this is because when looking at the connector for what should be j2(16 DBL), the big 10 gage red wire that runs through the fusible link, is there instead.
The connectors can't be swapped. Those bumpouts are different on each one.Do you think it’s possible that when they guy swapped in the 360, he accidently swapped two of the three bulkhead connectors. The reason I say this is because when looking at the connector for what should be j2(16 DBL), the big 10 gage red wire that runs through the fusible link, is there instead.
The sevice manual drawing may be showing the view from the inside.
I think the drawing is just upside down
A1C 16DBL is code for Battery feed, segment C, 16 Dark Blue, in other words fusible link. and that goes in J.
I can just make out the middle connector's bump in your photo.
So it may be like this when viewed from the front of the car.
You're ahead of me. View attachment 1715886450
With 11.5 volts in the run circuit, then check the battery votlage and the ammeter reading with the key in run.
That way ypou'll know if its just a low battery, or if there is a poor connection.
Welp. The entire dash is currently out of the car including ammeter. We pulled it and fixed a few problems behind the dash and it has been easier to work on.
We currently have the the two wires that go to the ammeter vice gripped.
Of course careful not to touch ground
That or wrong measurement technique.This is different from what you said. If i uderstand correctly, the upper right terminal should have 5 ohms, and the lower right terminal should have 0.5 ohms?
Does this mean wrong ballast?
OK. You can still check the battery voltage with key in run.Welp. The entire dash is currently out of the car including ammeter. We pulled it and fixed a few problems behind the dash and it has been easier to work on.
We can assume for now that the current is around 5amps.
Wow. Started reading this post.
OP stated this car had sat it a field for 20 years.
imagine every connection needs to be looked at!
anything diddled with has to be double looked at.
May I suggest using a test light, ( something that draws current) rather than a meter, to check for power on circuits.
Good luck
