M_Body_Coupe
I'm running a Carter TQ 9801 (Aftermarket with the attached electric choke) carburetor on my 408 stroker.
Having been working with the TQ carbs for many many years now, right down to installing adjustable air bleeds, etc...I would say I am fairly proficient with these carbs...however this issue I have ran into has me stumped and it may very well be the simplest of things that I'm actually overlooking, and perhaps not even caused by the carb itself!
So here is the combiantion:
1) W2 408 Stroker: Victor W2 intake, TQ on the spreadbore to squarebore adapter plate
2) Carb itself is setup exactly as the original OEM config: 0.095 primary jet, 0.137 secondary, 2110 rods, the ONLY difference is that I drilled air bypass holes in my primary throttle blades to help with the idle situation (Comp Cams 292 hydraulic roller cam, 240/248 @0.050"), which gets me a healthy 10" vacuum signal at 900 RPM, idle mix screws are out 3.4 turns, so I'm good there
3) The Carter mechanical Strip pump (M6902) is what is feeding the carb, that passes through a Holley pressure adjuster (12-803)
4) 16" drop base air cleaner, using K&N filter, I have about 1.5" of free space above the TQ vent tubes
I tune using Innovate O2 setup (LM-1 and LMA-3 AuxBox), which does give me a nice readout of AFR throughout the throttle opening and matching RPM ranges.
...and here is my problem: at WOT (either from rolling start, or at cruise) my AFR goes to a pig-rich 9.5-10 level!!!
I went back through all my tuning logs and as best as I can tell I started to run into this issue when I built the W2 motor...but several things changed at that time, such as: intake combo, fuel pump combo, etc, etc...so I have too many pieces moving to be able to peg this down to one change that's the culprit.
In that sense I went back to 'square one' so to speak: work one thing at a time until I get to "something".
1) adjusted the secondary air door opening (went super wide) but that made no difference...LOL, heck if anything my AFR dipped into the low 9s this time...I figured the extra opening actually caused even more fuel to be pulled
2) I disconnected the secondaries and re-did the test just on primaries: I expected a nice & clean AFR here, but oh boy was I wrong: still pig rich!!!
- not sure what to make of that though b/c perhaps by design the primaries itself may very well expect the extra AIR volume through the secondaries and so it could very well be that they will show RICH on their own (heck, I've never had the need to try this before so I really do not know what the baseline is)
3) I tested the phenolic fuel body to see if I have a fuel leak under the primary jet well, but all seems to be good here, no leak
So the only thing that remains is to tune down the Holley fuel pressure adjuster, force it to about 4-5 PSI and see if that make a difference because it could be that the extra fuel pressure the Carter Strip fuel pump (rated at 6-7.5 PSI) is putting out, as compared to the previous Carter Street pump (M6270, rated at 6 PSI) I was running, is forcing the fuel inlet valve off of the seat and simply flooding the carb at WOT.
This might make sense seeing as the converter flash is about 4000-4200 RPM and at that level the Carter Strip pump should be putting out pretty much all the pressure it has.
Outside of this, the last couple of times I headed out to troubleshoot I noted that at WOT and buzzing right up to 6500 my vacuum signal never drops below 5", in fact it actually seems to climb as I've seen it go to 6.5" right as I shift when the Tach light goes off (which is set to 6200). This is unlike anything I've seen before and suggests a massive restriction somewhere...but where??? Or is this simply the result of all that extra fuel NOT getting burned and the engine effectively choking itself off???
Needless to say, when I spotted this I made sure that the Diaphgram Connector Rod is adjusted correctly and during a WOT throttle blip I see the secondary air door swing open...so that seems to be working fine as there are no mechanical obstructions.
Alright, many things here...but what else am I missing???
Thanks as always!
Thanks as always!
