Caster setting
Not with stock parts but it’s a drag car only not sure how it would work going around corners
The more caster = steering harder to turn, particularly at slow speeds, parking lots etc .
You are actually lifting one side of car with the steering wheel, - more caster, more lift.
If a street car I would have it a 0 or +1 max
People complained about heavy steering if I went over +2.5 ish with manual steering daily driver .
5+ just isn't nec in a non track/race car, jmo.
My roundy-round cars have lots more right caster ( 10ish) cuz they turn left .
Agree I’ve seen some weird setups on circle cars but they work!
I just caint say this enough. Every SINGLE bit of this is in the Mopar Performance Suspension manual. Find a copy and read it.
I have the original one that came out in 74. Read every bit of it, it’s just radii of circles
I drive mine on both the track and the street. So I'll start with something in the +2-ish range I'm thinking. Sure something more than the 0 to -1/2 I have now!
@Dave999
My car does not squat - it lifts front and rear about 4". This is a CalTrac rear suspension car.
Couldn't find a good sideshot pic of it but this shows the front pretty well (rears are my smaller street tires, not the slicks I run at the track). You can see the top of the front tire is close to the bottom of the fender opening.
Here it is a bit after the hit. The body just lifts almost straight up.
@Dave999
Might need some stiffer shocks in back to hold the rear down. Of course that’s the way we raced for many years.
I had to extend the drag like on passenger side to get it all even. No toe out or in thru travel now. A lot of in and out work checking length. Now both tie rod tubes are same length and on same arc.
