Change ing from automatic to standard
They were the same console, you will need another top plate, would have to be the correct shifter. Some other members will help out with more details. In Short, yes you can keep it, just use the right parts
If you decide to run the A833 overdrive behind that 360 stroker, make sure you put a bicycle in the trunk, so you don't have to walk when the 20tooth mainshaft gear explodes .
They are great " crusing" unit, high HP, and Rev Clutch Dumps? No....
My car has broken three of them in various ways; 2 with my 367HO and one with a Smoggerteen. When the OD blows up it usually takes the entire trans out. But one time, I was able to drive all the way home in direct, a distance of ~14 miles. After subbing in a replacement OD kit, a few weeks later, the 318 took the input gear out. I didn't count that incident because I musta missed a piece of debris, or just didn't see the damage at the earlier inspection. In any case, that alloy-box is now available, lol, and the broken parts are on my wall of shame.The other gears seem to be strong enough for my combo; maybe because I have a serious traction issue.
I find those gearsplits just too daymn far apart for spirited driving, and the total range is too large. It's dang near impossible to have a nice Second road-gear.
The ranges of the A833s are;
At 2.66 and 1:1 the regular box has 2.66/1=2.66
At 3.09 and 1:1, the Commando has 3.09/1=3.09
At 3.09 and .73, the od box comes to 3.09/.73=4.23
With a GVod the numbers are;
2.66/.78=3.41 Tight splits, adequate range, adequately high cruise rpm.
3.09/.78=3.85 What I run, but already getting long.
3.09/(.78x.73)=5.43 stupidly nice with the right combo.
If you have too much starter gear, it just goes to waste, unless you need a parade gear.
Most performance combos with long overlap cams will rapidly loose fuel-efficiency below ~2000rpm. 2200 to 2400 seems to be the sweetspot.
After about 3 years, I quit the od box in 2004 or so.
If you can't find used parts you need, Brewer Performance is the go to place to get what you need. You will need some mechanical and fabricating skills and tools to get the job done.
I had a few, only one I ran was in my / truck.. if I remember, the MP books said Don't run em hard
