Change to Large Bolt Pattern
gljplc
Member
Pineville, Louisiana
My '67 Barracuda convertible is in the paint shop. I would like to change it to large bolt pattern for billet style rims.
I have a 7 1/4 rear end presently.
What is the easiest (least expensive) way to convert to LBP on both front and rear with the 7 1/4 rear end??
I plan to install an 8 3/4 rear, but even that would have a small bolt pattern on it and require a change.
I certainly appreciate any advice.
GLJPLC
Louisiana
Using '73 and up upper control arms and one of the spindles/brake assemblies in the link above, you should be able to find something reasonable
