Charger/Commando valve covers.
Thanks for the info and photo. THere you have it. I will correct my post above.
You bet Mike. Also, I have reason to believe the head gasket on the passenger side is blown, so at some point I'm going in to replace. I have no reason to believe that my engine is relatively untouched and in original condition aside from what I done, new carb. So those head gaskets should be factory. I think there is a thread about wanting to get a hold of factory hipo 273 head gaskets somewhere.
Don't be sad Karl.
You didn't get the bill for those fins. :lol:
And here is another photo of the 67 covers with the 2 wire spark plug wire holder and the pcv grommet. It has the wide heat protector as well. Something I just noticed is the raised area around the stovepipe and grommet areas on the 67's that the earlier covers don't have.
I have access to a set of those in the same condition, what. Would you say the value is, selling here ?
