Check this out!!!Hopefully this system will work for all of us
Heating / Cooling / AC
  1. Hallzy
    Hallzy Well-Known Member
    116
    52
    Jan 13, 2017
    Alberta,Canada
    Local Time:
    8:51 AM
  2. mopardude318
    mopardude318 Well-Known Member
    9,350
    464
    Jan 7, 2005
    Gilroy, Ca
    Local Time:
    7:51 AM
    Sweet, but I don't like electric fans.
    • Agree Agree x 3
    • mopar65
      mopar65 Well-Known Member
      1,598
      1415
      Mar 23, 2008
      Laquey MO
      Local Time:
      9:51 AM
      But I do.
      But I bet I won't like the price. Lol
      • Agree Agree x 3
      • Like Like x 1
      • lilfontleroy
        lilfontleroy annoyinglilLeRoy FABO Gold Member
        945
        731
        Nov 20, 2017
        USA
        Local Time:
        9:51 AM
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
        15,435
        4489
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        9:51 AM
        Not in million years will I install an electric fan.
        • Agree Agree x 4
        • moper
          moper FABO Gold Member FABO Gold Member
          15,489
          1587
          Dec 27, 2004
          eastern CT
          Local Time:
          3:51 PM
          Cool. A solution to a problem I've never had...lol. But I'm sure some can use something like that.
        • Ccas
          Ccas FABO Vendor FABO Vendor
          76
          35
          Dec 7, 2016
          Hatfield, PA
          Local Time:
          10:51 AM
          These guys were definitely thinking outside the box on this one. Space availability is definitely a nagging issue for a niche amount of owners who feel they need an electric fan kit. (I can think of about 4 or 5 very unique car/truck applications where you just physically can't get a fan kit to fit and are forced to put the fans on the front side) Even for those owners, I don't like that a good chunk of core has to be removed from the center of the radiator. What happens to the flow when the cooling tubes reach that box? Cavitation? I don't like that the fan has to be literally mounted to the core. Vibration? I don't like the row of vents on the one side of the radiator and I am willing to bet that none of us are going to like the price. However, I'll be sure to tune in if one of you wants to purchase and tell us all about it. I'm always open to new ideas and appreciate when risks are taken.
          • Agree Agree x 1
          • famous bob
            famous bob mopar misfit
            11,800
            3057
            Aug 14, 2011
            okla
            Local Time:
            9:51 AM
          • jos51700
            jos51700 Well-Known Member
            4,514
            1245
            May 24, 2009
            Bel-Ray
            Local Time:
            9:51 AM
            It's a good idea and I love that they fitted a shroud.
            That said, they're losing a LOT of cooling by not putting on the little rubber flaps that a late model oe radiator has
          • Jimacuda
            Jimacuda Well-Known Member
            1,332
            328
            Nov 10, 2006
            Phoenix AZ
            Local Time:
            7:51 AM
            "...might change your life"...thats hilarious.
            cant have much of one going on if thats the case.
            that fan better be very well balanced.
          • fishfly
            fishfly Well-Known Member
            61
            15
            Jul 23, 2017
            usa
            Local Time:
            10:51 AM
            I think all fans should be very well balanced. This one is no different from another. As far as the tubes they could just diverge...very very small head loss in even a 90 degree bend on such a small area of tubes given the total dimension..and one would need to consider the efficiency of the entire radiator which will likely exceed what one would need anyway provided they have a properly tuned engine. The slots on the inside that increase flow I'm not too sure about. It depends on how that air flow is diverted. It might not be good for warm air being pulled from the engine compartment and into the front of the fan. However they might channel that flow somehow that I didn't see in the pics. Without knowing much more detail looks like a good problem solver. I don't have a dog in the fight though..no electric fan if I can help it.
          • harrisonm
            harrisonm Well-Known Member
            1,952
            1259
            Jan 16, 2005
            Topeka, KS
            Local Time:
            3:51 PM
            I bought a direct fit Griffin radiator with a custom shroud and electric fan about 8 years ago. No matter what I did, I could not get the level of cooling I needed. I finally pulled the electric fan and went with a conventional fan and shroud. All good now. If you like electric fans, those do look cool.
          • diymirage
            diymirage HP@idle > hondaHP@redline
            14,949
            7332
            Oct 12, 2012
            michigan
            Local Time:
            10:51 AM
            great, another solution to a non exiting problem
          • Hallzy
            116
            52
            Jan 13, 2017
            Alberta,Canada
            Local Time:
            8:51 AM
            A non existing problem for small block, pretty limited space after big block swaps
          • diymirage
            14,949
            7332
            Oct 12, 2012
            michigan
            Local Time:
            10:51 AM
            how did they solve it with the M code cars?
            the ones that came stock with a big block ?
            my point is, they were installing both big and small blocks in A bodies all throughout the late 60s, and they fit, radiator, fan and all
          • Hallzy
            116
            52
            Jan 13, 2017
            Alberta,Canada
            Local Time:
            8:51 AM
            I'm not arguing your point just saying space is more limited and options are nice there can always be improvements made to the way things have traditionally been done.
