Charlie's Dart
Active Member
OK guys I bought an electronic distributor for my 69 dart with a 340 , also got a Delco electronic module (hei) and mounted it on the bottom of the distributor . I know the 2 wires from the dist. plug into the module and the other side plugs into the coil but my coil only has 1 terminal , what do I do ? And are the wires that plug from dist into the module reversible ?
