Rice Nuker
Let the Coal Roll!
Autoxcuda, are your SCAs Redline water wetter? What else do you suggest or use besides RO water? What are your results overall?
I have read that Water Wetter and 50/50 cools better than 50/50.
I wondered if Water Wetter was also an SCA type additive.
We are flushing the Jensen (factory 440) this weekend with "DEI Radiator Relief" and tap water, followed with 1 pound of citric acid and 3 gallons of distilled water - running it for 30 minutes, another water run for 30 minutes then 50/50 coolant pre-mix. I will be putting a piece of screen wire over the rad inlet prior to the procedures.
I am adding a Gano Filter pretty soon after.
http://ganofilters.com/index.html
So you are saying RO water is the same, better, or worse than distilled water??
I'm using straight RO water with coolant additives that include SCA's. I'm only at 76 mV electrolysis voltage test.
