If you can crack the alternator into the frame pieces, you can soak it in Simple Green or Berrymans. It gets AL very clean. Etching mag cleaner works good to, but leaves it a little gray. To get the rotor back into the brushes, you stick a paperclip into the brush holder hole to keep them retracted, insert shaft, then "pull the pin"
