Clutch pedal return ??
Ya your an old fart like me. I too have owned a lot of manual shift cars over the last 50 years and have done a lot of 4-spd conversions for my customers.
The spring between the arm and crank just tightens up the slop between the two and keeps the crank tight to the arm. The hole in the rod is D shaped.
Also forgot to mention that the bell housing has a knotch with a hole for the return spring to go between the housing and block as shown in my pic.
So you guys screw up your **** the way you want and I'll screw up my **** the way I want.
All of my pedals return to the bump stop and have nice smooth, full travel doing it this way.
So do mine, with one spring correctly attached.
Here you go. Right out of the 1973 FSM. One spring, NOT hooked to the bell crank.
Just like the hundred I’ve seen.
When you push down the pedal how much play is in your pedal and linkage before the arm starts moving?
ZERO. WTF? Do you think I’m stupid? I don’t put up with junk **** like that. My **** works. WithONE SPRING like the FSM shows.
Well if your just going to get all pissed off then I'm done with you. All I did was ask a question.
My bell crank has a spring hole so I used it.
Ok. I see the second spring. Is that an Ebody or something.
Because the second spring, if it hooks to the clutch fork what does it hook to on the other end.
That is a **** drawing.
Pedal should return all the way to the bump stop. Do you have both return springs installed?
One between the arm and crank and one between the arm and bell housing.
Looking at this picture begs the question of how your springs are following the picture you posted? It doesn’t because the picture shows the spring on the other side of the bell crank and on the opposite side of the clutch fork.
You have to explain that. And then explain what happens if you remove the second spring.
.....it looks like playing with the adjustment is my go to trial and error.
IMO, reread the first sentence in post #3. Work off that.
The .060" below is not gospel.
The clutch peddle OVER CENTER spring under the dash works in both directions.
First, it assists in peddle effort to help your leg release all pressure plate load on the disc.
Secondly. once the peddle reaches its over center position it pulls the peddle up to is stop.
You can prove this when you "toe up" the peddle and it stays up. And pushing the peddle down past center and it doesn't return.
How I see it, a B&B PP spring load on the fingers should pretty much be enough to hit OC position on the pedal itself. The fork spring keeps the release bearing pulled back off the PP fingers in pedal up position and also provides tension on the adjust rod components to maintain adjustment. The correct washer has a recess for the nut to fit in and a nub/flat in the ID to close up one section of the FLEX type locknut onto the flat of the adjust rod. The fork spring might assist the peddle up slightly, but stock replacements are surely no match to overcome an OC spring.
Out of the box...
FWIW, If the Lakewood bell itself is 7.380" (stock bell length) and a 3/16" block plate is added, the pivot may be 3/16" further rearward if the Lakewood doesn't compensate for it.
If the pivot is moved rearward, you'll need to adjust the clutch adjust further out to compensate. This also causes more angle on the fork when depressed since the pivot point is further away from the fingers. In turn this can increase the potential for a bearing retainer clip to twist out of one fork tip cup and a fork tip to twist off one pad of the release bearing.
Edit: explain how the second spring, which is on the other side of the clutch fork isnt pulling in the opposite direction of the other spring.
There are no direction lines I can see. Just garbage.
If i'[m looking at the same photo as you, I see two springs, one for a 6 cyl. and one for a V8. Two different apps. My 340 has one spring on the fork and a cross over spring at the pedal. No issues. Just a thought, are all the rods and external spring for a LA, 833 V8?
Yeah, that drawing is wonky.
If you want a wonky drawing, Look at the 64 FSM and compare it to a 64 car. Not even the correct clutch fork and linkage that's pictured in the book. Plus, on mine, the clutch fork spring connects the fork to the K frame. There's even a little slot for it in the K frame. It puts the spring right in line with the fork. One end of the spring has a long end with a hook and the other is short. I've never seen a second spring, or a hole in a Z bar for a spring. That doesn't mean there's never been one, or that there's no reason for one. I could see it being basically an anti rattle spring, because it would serve no other purpose. Since the Z bar moves with the fork, all that spring will do is tighten up the fork to the rest of the linkage. It would certainly be good for that. That would assure that the only free travel would be between the throw out bearing and the pressure plate fingers. On those with only one spring like mine, that single spring does both jobs.
That top lever on the Z bar looks like it needs to be bent outward toward the fender a little. I had to do it on my 1969 Dart to get the rod in the center of the firewall hole. It's probably rubbing on that boot.
Okay this is what I have found with both a Lakewood and Quick Time bellhousings, go under the car and see if the clutch fork has bottomed out on the bearing retainer before the peddle reaches the top of its travel and the clutch linkage has to pivot and pull away from the fork to take up the rest of the travel. If so the cure is to shim the clutch fork pivot out away from the bellhousing. On my car I used a 3/16 shim between the fork pivot and bell on a Quick Time bellhousing with a Long Style PP ( you will probably need a thicker shim with a B&B PP). To get mine to the right fork travel with a 1/4 inch air gap from the clutch levers to the throwout bearing for the peddle to return all the way with a light spring from the clutch fork to the bellhousing. My clutch only has around 600 lbs of static pressure, your should be 2400 lbs or more so it should return no problem.
Merry Christmas every one!
