The "over center" spring is the huge rusting thing at the very top of the photo. Once the pedal moves far enough to get it "over center" that spring is trying to push down the pedal. The RETURN spring is a very light spring underneath, connected to the release fork somewhere. and trying to pull the fork to the front of the car which helps disengage, but is really only helping the "play"
This all only works when
The clutch parts are all correct pieces
(Read that AGAIN!!)
When the clutch disc is not terribly worn out
When the thing is adjusted properly---there is only one---on the pushrod down at the fork, which changes the pushrod length.
And when the Z bar is not only correct, the engine sitting properly on poroper mounts (not some welded in conversion mounts) but also that the Z bar is NOT DAMAGED and or rusted, causing the levers to be displaced rotationally from their proper relationship
You can see it below. AN979 on the pushrod I believe is a lock nut. If not it is the adjuster. AW483 is either the adjuster or a washer. AG412 I believe is a rubber anti rattle cushion. The RETURN SPRING is right there, FS480
