POS Dakota
Anti-Socialist
ok...so now I am building two motors! My 426 is going to wait a while because I am undecided on a lot of things, and it is now going into an a-body. Not my dakota. More on that late summer.
408...
Chambers will be 62cc's and static comp will be 10.2:1. Dynamic comp will be about 9:1. (ivc of 41.)
Cam spec I am looking at is a comp "off the shelf". Indications are that it would be a nice cam for me...hold on before you judge and see my logic
The cam is a comp hyd roller 20-812-9. (because I dont want to deal with a solid, that's why. lol) Specs are 230/[email protected], lift is 541/537....BUT I am using the hughes magnum shaft rollers with a 1.65 ratio so the final lift would be I think about .595/.591 if memory serves correct...correct me if I'm wrong!
Take into consideration this engine will be in a dakota over 4000 lbs. for street, cruises, and some recreational tracktime.
I have three gearsets sitting here for my 9.25...one is 3.92, another 4.10, the others 4.88.
I drove the 4.88s for a while and they were even a ***** with overdrive. lol
I think i will use the 4.10.
Questions:
1. What do you think of the cam using the 1.65 rocker ratio?
2. What do you think about stall speed? I think torque is gonna be very strong down low, so I might not need so much. 2800?...feel free to correct me.
3. Who can tell me about piston to valve clearance with a .595 lift and as close to zero deck as I can get? Of course I'll have to check, but whattya think?
4. Will this amount of lift trash beehive springs with a max shift point of maybe 6200-6400 if that?
5. Oh! are the LA retro hyd roller lifters and the mag lifters the same height?
I need to know the pushrods will work.
I have a good idea what some of these answers are, but I like to bounce the questions off others who know just for reality check sake. If you have suggestions other than what i have outlined, shoot!
Any help would be appreciated.
I am trying to get my final "grocery list" together by friday so I can place my orders and get rolling ASAP!
408...
Questions:
