Ridge is... well, a Ridge. it barely catches a fingernail... doesn't stop your fingernail... I say it's a very low ridge
Yeah, you got some wrong parts there, I believe. Rings are suspect.Ridge is... well, a Ridge. it barely catches a fingernail... doesn't stop your fingernail... I say it's a very low ridge
Yeah, They show a Copper color all around but look smooth... You got any?Hmm. As my limited mind wonders, as the power was out for a while, do you replace the rod bearings, while you are there? I'd damn sure plasti gauge em, since the same guy did the rings....
Does this look weird to anyone?
I took apart a motor that I thought was a stock/unmolested 273.
It was smoking and using alot of oil.
After a Freshen up on the heads it was getting around 120psi in the cyls.
I pulled the piston with the lowest 115psi, removed one of the rings and put it back in the cyl
the End-Gap was around .132 - .134!!!
I was expecting to see an .020 gap, Was I wrong?
.Aww man...I have some cheap *** snap bore gimmicks I drop in there, at a few different levels and side to side locations then measure them with a caliper. Is it as accurate as a dial bore gauge? Heck no, but it's pretty close, for what I do. So you were going to shove the ring around and take end gap readings n different places? That outta tell you something..taper, at the least
That's very true. We used to have a local family run machine shop. They were very good........until the father passed that founded the business and the son took it over. To this day, the guy thinks he knows it all. Can't tell him anything. I haven't even seen him in over 20 years. Anyway, one of the last times I saw him, he was measuring "some poor soul's" bore with a hand held telescoping dial bore gauge. I said, "gosh, is that the most accurate way you have to do that?" He said "yeah" "it is the most accurate". I just walked over and asked to see it. I asked him what his reference was to the center line of the crank to the bore as I put it into a cylinder. He said "huh?" I said "yeah, that's what I thought" and I've never seen him since..
dial bore gauges are for production machining and those who do not know how to use telescoping gauges and micrometers. Also they are only as accurate as the user and the standard.
See my parentheses above. You are 100% correct. You have to know how to use tham.A good dial bore is accurate to .0001 of an inch or better (if you use it right). Anything else, not so much. I had a machine shop tell me, after I told them what I wanted the intake side of my heads milled, that he would mill them the same as he did Chevy heads, cause Chevy was racing long before Chrysler. I told him he was wrong on both counts, and found a different machine shop. Funny what you remember...
Hey Triple R Should I wait til I have Number Stamps to tear this down or just go ahead and do it and keep the pistons organized in a tote?See my parentheses above. You are 100% correct. You have to know how to use tham.
How far do you plan on going with machine work? If you plan to have the rods resized, it won't matter where they go back, only that they face the right direction when you install them.Hey Triple R Should I wait til I have Number Stamps to tear this down or just go ahead and do it and keep the pistons organized in a tote?
I have one of those 2 litre soda totes that holds 8 2-litres... thanx man
I resize rods and use good rod bolts on all my builds. I also won't cut corners on the crankshaft. It gets turned, unless it's standard on the high side and the journals are ROUND....and that ain't very often on a used engine.Machine work? I was just gonna buy a Hone and dig in
Yes they are.The removal of the normal gray on the bearings is very uniform. I wonder if some old school engine builder scotch-brited the coating off. Are all of the rod bearings like that?
How can I determine Journal Roundness Triple R?I resize rods and use good rod bolts on all my builds. I also won't cut corners on the crankshaft. It gets turned, unless it's standard on the high side and the journals are ROUND....and that ain't very often on a used engine.
Machine shop.How can I determine Journal Roundness Triple R?
