i have some smog heads on my 318 , cylinder pressure is 100, i have access to some 67-68 heads that arent smoggers, what will i gain ? bottom end is new with flat top pistons.
if you have the "302" smogger (not) heads you'll lose cr by swapping to the early heads. otherwise you'll gain pratically nothing.
why only 100psi? u put a aftermarket cam in that thing? even a 7.5:1 360 with 200k on it will make at least 120psi.
I think the 68-70 318 open chamber heads are still very small. like 60ccs or something. I dont have the casting books to say exactly tho... anybody have one handy?
