compressor electric motor bad
rbkt65
jerseyville, illinois.
which 1 to buy? I bought it in 1989 and it is a 5 hp A. O. Smith. Found a couple online, Man are they expensive. Going to have this 1 rebuild for spare for my other comp. Just want to get 1 put back on asap. Any suggestions?
You're going to buy a new motor and "rebuild" your old 5HP motor to have as a spare? I don't know about prices where you are, but that wouldn't make any sense at all down here.
Unless it just needs bearings it will not be economical to rebuild. I just priced out new motors recently…very expensive. Make sure you get the same frame size and rpm.
my old one was 40 years old ...how much more do you need
What is wrong with it? Bearings? Start switch? start/ run cap? If it is more than that AKA if it needs rewound, it may not be worth it
I had a 1/2 HP motor off of my dad's Rockwell drill press rewound about 10-years ago because we could not find a replacement with the correct frame.
It had aluminum start windings and copper run windings, but the armature was in wound in the middle 1/3.
They rewound it with copper starts and wound 2/3 of the armature, so now it has twice the torque than before.
It cost me $350 back them, but to still have the correct motor and more power was worth it to me.
Tom
The rule of thumb was $100 per horsepower complete rebuild cost vs new. As said if it is just bearings and you do it yourself Cheap. Our shop recycles pretty much everything 5 horse and below unless it's just bearings. It's generally cheaper to buy a new low horsepower motor.
Make sure sure tank is still in good condition. You don't want to speed a lot of money on a new motor only to have a rusted out tank start leaking.
I went through this a few years ago. What is the typical motor class for a compressor? Open Drip Proof (ODP). What usually dies on an ODP single phase integral HP motor? The starting switch. What does it die from? Air-borne contaminants.
As a shop is always dusty, against the advice of everyone , I went with a TEFC (Totally Enclosed Fan Cooled) motor to protect the starting switch. So far so good.
