Patch
Patch
I looked all over the brake section...but here goes......I have a complete donor disc brake set-up off of a 73 Dart.......Upper arms...lower....everything. In one forum I read that you DO NOT use the 73 lower control arm as it is wider.....another forum says use it and makes no mention of it being wider at all........Upper control arm yes...= bigger ball joint........lower control arms........anyone? Thanks in advance......Pat
