[I have googled for days... just not finding the right thread, or have gotten to dead links. I may answer my own question here as I'm going back out to do more probing.]
I'm converting to HEI (Classic HEI kit) and need a good 12v source for crank (Ign 12) to feed the coil. I may have caused my own problem because I first simplified by removing the old components/connections.
I am using the wire that went to Pin 1 of the ECM for 12v for Run, but then lose 12v when I crank. (This is expected because it comes off Ign 11.) The engine cranks, so I know I am sending voltage through the starter relay. Am I going to need to tap that connection for the 12v Crank source?
I no longer have the ECM, Ballast, and have bypassed the seatbelt safety relay. I have found all the 12v sources for Ign 11 (Run) but am trying to find 12v for Ign 12 (Start). TIA.
Once I get this tackled, then I plan to add a relay to feed the 12v from the battery.
