Jun 26, 2020 #1 H Harveybos Member Joined Feb 6, 2008 Messages 9 Reaction score 1 Anyone seen one of these before? It came fitted to my 69 Dart Custom. Appears to be an aftermarket part that connects to the radiator overflow pipe.
Jun 26, 2020 #2 BWDart Well-Known Member Joined May 25, 2005 Messages 1,392 Reaction score 277 Location New Braunfels TX Autozone special had one on mine worked ok
Jun 26, 2020 #3 RedFish FABO Gold Member FABO Gold Member Joined Sep 5, 2007 Messages 26,688 Reaction score 6,424 Location Anderson SC I have a very similar bottle in my 67 today. I had to relocate one horn to mount it where I wanted.
Jun 26, 2020 #4 kursplat Well-Known Member Joined Aug 24, 2010 Messages 4,309 Reaction score 3,345 Location so cal it's a coolant recovery tank. are you going to use it? nice period, albeit aftermarket piece.
Jun 26, 2020 #5 H Harveybos Member Joined Feb 6, 2008 Messages 9 Reaction score 1 kursplat said: it's a coolant recovery tank. are you going to use it? nice period, albeit aftermarket piece. Click to expand... Thanks for the info. Yes, it’s cleaned up and refitted!
Jun 26, 2020 #6 RedFish FABO Gold Member FABO Gold Member Joined Sep 5, 2007 Messages 26,688 Reaction score 6,424 Location Anderson SC It will function better mounted as high or higher than radiator. There isn't enough vacuum/draw to pull coolant back from a very low location.
Jun 26, 2020 #7 BillGrissom Well-Known Member Joined May 10, 2009 Messages 8,240 Reaction score 1,128 Location Sacramento Looks like the plastic might still be OK. Few OE coolant tanks around since the plastic hardened and cracked from years of underhood heat.
Jun 28, 2020 #8 H Harveybos Member Joined Feb 6, 2008 Messages 9 Reaction score 1 Thanks for all the responses - much appreciated!
