Coolant Overflow Tank/Reservoir
I started out doing this mod.
How To for Heaterbox Motor Modification
Then I found a 90's ? Geo Tracker heater motor. Also bought a sqirrel cage from Grainger with the fins pointing opposite from stock. Hole was small on cage so drilled it to fit. I'm having trouble finding it on that site but I did mention it here. I will keep looking.
I am using tis little one on my '69 Dart. Had to make a simple bracket to mount it. Fits to the right of the radiator near where the horns are. Expensive? Yes, if you can fabricate your own (I can't).
Meziere Enterprises WR100S Meziere Recovery Tanks | Summit Racing
Here's a couple. I did use a 1" spacer where I bolted it to the radiator support. If you have a wide radiator, it probably won't work.
