bbrroowwnn
never re member
.652, 272@.050. It is what it is.
Wow that is a big cam.....it probably still doesn't idle smooth at 1200
This is the old-school Direct Connection "Mini-Express" mushroom lifter setup "comes very close to roller cam performance at about half the cost". Originally 316 advertised, 278@.050 measured at the cam grinder's, .654" lift with .024/.028 lash. Centerline 107.
I had to have it slightly reground because some of the lobes had lost their taper and wouldn't spin the lifters. It came back as 312 advertised, 272@.050, .652" lift with .018/.018 lash. That is actually a slightly faster rate and more net liftI put it in at 105.
What website? Hope it's not YB![]()
Video with sound from the rear in post #42. You can tell there's a cam all right. Kind of ruins the sleeper image, unfortunately ;)Wow that is a big cam.....it probably still doesn't idle smooth at 1200
I would not be bothered except with a 2.67 1st gear and 3.91 rear, it's idling at about 8 mph. Would be no fun in traffic at all. But I live in BFE and it's pretty unusual not to make a traffic light on the first cycleIn your case, a 1200 RPM is pretty dang spanky. I've never been bothered by idle RPM. I've had cams back in the day that if you can get a 1500 RPM idle you'd be doing good.
What were you running, the old R286-500 roller (286@.050, .750 lift)? Those liked a 1500 rpm "idle".
