rebrabtrebor
Aussie A body AP6 1966 V8
hi, looking for an answer! Running a 273 1966 Valiant, but have a miss fire under load. Electronic ignition was fitted prior to my ownership, but seems to be installed well. can anyone point me in the direction of correct part number for spark plugs? NGK preferred! I have changed Dizzy cap, arm, leads, plugs (same as what came out) etc but it has had NO affect at all.
Also thinking it might not be ignition at all! may be fuelling problem from old 2bbl carb, but want to check the obvious first... :burnout:
thanks peeps.
thanks peeps.
