Ironmike
Pressed out all my front susp bushings, everything's blasted and plan to press the new ones in tomorrow and spray on a coat of primer.
I noticed 2 things today that I'm questioning. Hope you guys can set me staraight.
1, I noticed my passenger side strut rod has a slight bend. Rolling it across a dead flat welding table shows a slight "tweak". Should I straighten it a bit, replace it, or install as is? It's really very slight. Unnoticable to the naked eye.
2. 1 torsion bar has a very shallow "nick" on it. Don't know how it got there. I removed 'em with the lower control arms.....plop right out with no effort. I've heard that if they're marred at all, replace 'em.
Should I throw it back in ,or replace ? As above a very minor "ding".
Everything going back on is brand new and I hate to seem cheap, but money is getting a bit tight. New motor, fuel lines, brake lines, wiring, front suspension, etc. You know what I mean?
