OP, how about what appear to be water stains up nearer to the header flanges above both those leaks? Are you sure it is not something from the exhaust area leaking out/around the header gaskets?
I think i saw a W2 that had a crack down there too. Torquing down on a bad head gasket or piston interference? Try some blue devil block sealer. Stuff works.
I noticed that. The flat black color is a great absorber of radiant heat from the headers! Gotta wonder what the net temp effect is... + or - ?Love that oil filter.
No they aren't original to the block.The more I think about this is the 4th block I've had them on.Stop leak.
Yes. I have seen that. Once.
Block was cracked too. 1976 or 79 block iirr
You have a 72 block, j heads are 71-73. Are they original to the block?
