I understand that the balance of the 318 and 340 rotating assemblies are not the same. @Illahe are you saying this is a 318 forged crank? I can only assume this rotating assembly was balanced to accommodate the change in piston weights (FORGED TRW’s) but maybe not?
So far I verified that my harmonic balancer is neutral balanced! I am in the process to see if I can verify if the torque converter has any weights welded to the front face. So far I didn’t see any.
So this is concerning because my assumption that the rotating assembly may not be balanced and this might be the cause of the vibration?????????????
Comments?
Comments?
