Crazy Custom EFI Idea
That doesn't give you the unmolested stock carburated look and there are places like here in BC you can't put Fi on a collector car without losing your collector status .Why do you think Holley is doing it and why do you think they believe the market will support a 2k price tag ?
Take bowls and plates off a 3310, run 2 BIG injectors per side like this.....Trim bowls to look like covers and run it MS2 batch fire mode. probably not much better than a carb but itll start in the morning with one kick. These were ~$695. FAST EFi2.0 is the same setup as I described. See the fuel lines?
View attachment 1715060793View attachment 1715060795
Thats basically what Im going for, the bowls will just basically cover everything up. To create more room and to prevent cutting up metering blocks, I'll probably end up fabbing up some spacers out of steel and then make them look like metering blocks.
And there is NO way my little 360 would know what to do with that much fuel :lol:
The injectors I'm looking at flow 42 lbs/hr from the factory, and can support up to about 70 lbs/hr if I boost the fuel pressure.
That's not a bad alternative though... Definitely some inspiration in that.
And @KitCarlson, I know that an MPFI setup would be easier and run better, but again the whole point of this is to make it look very passable as a standard carburetor, and unless I make it direct injection and hjde the injectors in the valve covers, TBI is really the only way to go
Looking forward to the post when you update us on the project completion. Learning by doing is a good thing, it helps calibrate intuition, with reality.
A real stealth system with performance, would place port injection under intake, near valves. :)
