sport74
Okay guys I've got a crosswind AKA air gap clone that I've put on my 408 stroker which is Magnum based. I went to put the air conditioner and alternator bracket on and the bracket is hitting on the air conditioner side on a boss on the intake. It also looks like it will be hitting on the thermostat housing as well once I remove the boss. I'm wondering if any of you have had this issue before and what you did to fix it I'm trying to retain the factory Serpentine setup without doing a bunch of major modifications and worrying about pulley alignment and things like that. My plan is right now used to grind down the boss on the intake maybe drill and tap it for a bracket if need be later on but to cut one corner off of the AC bracket and Run 3 bolts on the compressor. Let me know if any of y'all have done this or have done anything different to make this work any help is greatly appreciated thanks so much.
