yellow rose
Overnight Sensation
I don't know about saving all valves, though. Valve stems can wear like an hourglass and that makes them hard to get an accurate and consistent guide to stem clearance. Unless you run positive stem seals, you are losing vacuum to too wide of clearances.
I mic the stems and always run a positive seal. Unless you are pulling pan vacuum then you can leave off the seals and save some power.
