Damaged pistons
mod5v
fortworth
So I got this motor on trade and when I pulled it apart I found 2 pistons with top land damage. They are SRP forged flat tops. I was just wondering what would cause this kind of damage. Maybe got hot and seized in the bore? Or maybe just to tight clearance.
Ring ends butted together. I would check them all very closely. In fact, I wouldn't run any of them just because.
Ah ok I will check a couple of the ring gaps just for my curiousity. One piston had a valve drop but when I tore it down I found these other 2 also. So am trying to decide if I buy 3 new pistons or a complete set. It has been internal balance +.040 360 so I would like to keep pistons as close to the same weight to keep rebalancing to a minimum.
This guy put 'regular' in, but only once! You may of had a lean condition or a timing issue possibly. There is a hint of the top ring rubbing ends like RRR suggests also.
Lifted and melted the ring lands at the thinnest spots, lean, anywhere else...end gap gap issue as well.
