68383GTS
What is the biggest tire you can get under a stock 68 Dart?What size rim did you use?What offset?Also will a 15 in wheel fit on the front without any clearance issues.
I thought of moving my tubs over to the frame.But my car is pretty rare I don't know if I can bring myself to do it.But then again if I loose traction and hit a tree with skinnys on the back that is not doing me any good either.
If I move the tubs over to the frame will a 275X15 fit?
Thanks,Jim
Thanks,Jim
