It would be handy if you would post a photo. If it looks similar to the one on the left, it's a ground
So far it is not working. Old one read low new one reads high.Dustedu2,
If it ends up working out for you or not, please keep us informed. These regulators are a major pain, and if you have found a good source for a reliable replacement, let us know about it.
Ronny
with the old limiter the gas guage, when I fill the tank, tops out at 3/4 and when it reads empty it could still have 1/2 tank. Temp gauge reads lower than the aftermarket one. With new limiter, gas gauge goes out of sight when 3/4 full and temp gauge goes all the way to the right when it is running 191° Thats what I mean by low and high.The stock gauges are only range indicators . There are no numbers on the screens. What you consider to be low readings or high readings from this type gauges means very little.
