I'm looking at the dashboard voltage limiter and it has a piece cardboard under it. At first I thought it just fell into that position, but upon further investigation i see that it was intentionally put there. Punched specifically through the center pin that goes to the brake warning lamp and the condenser wire that plugs into the same spot. Anyone know why it may have been done?
Also in many attempts to get a fuel gauge working I've swapped that part around from various dashboards I have lying around to no avail, I've read it may be a ground issue. The sending unit is grounded to the body of the tank and on 3 cars the gauges register from time to time, but never seem to be accurate when doing so. Any help with that?
Thanks
Thanks
