Decent Slant 6 carb, intake, header setup
Thanks, I did not know that. Do you have pictures?
I have these on my computer. If you need more angles, let me know and I'll grab some today. The last picture was taken with the Slant 6 exhaust still in it.
I sourced an inexpensive 2bbl plate adapter to transition from a Super Six 2bbl intake to a 350 cfm Holley 2bbl.
I did have to use a burr bit to smooth the port transition between the parts, but it was a perfect size carb for my Slanty. I did have Dutra Duals, the smaller Dutra spec'd cam and some head work.
I tried using a Holley 500 cfm 2bbl, but it was lazy ot low and medium rpm. Once it started to rev though, it mad more power. Not practical on the street with the freeway oriented gears I was running.
Looking to make my slant 6 a lil' badass for the time being. What are some decent set ups? Daily driver conditions.
My '65 has a stock 225 with the 1bbl, a 904 with a shift kit and deeper pan, currently a 7.25 with a peg leg 3:55 ratio.
I'm blasting my 2bbl intake this week and rebuilding my 2bbl Carter soon to get installed for a lil gitty up!!!!!
my previous set up was a stock comp Clifford cam 264 super six two barrel 7.25 3.55 gears i would run low 11s in the eighth of a mile, pretty snappy that was with a 4 speed though. would be getting a solid 18-19 mpg.
Now with my current set up im in the 20-22 mpg way more power/torque out of the 225
I played the Slant 6 game for 10 years. I even had Doug Dutra build my motor with most of his speed secrets for them. It was a great running Slant 6, but it was still a 18+ second quarter mile car.
Save your money, tune your stock motor well and consider the following.
In the end, I pulled it and put a junkyard 5.9 Magnum with a 727 in my car. I set it up so I had EFI, and did the beer keg manifold mod with headers and a small cam.
I got 4 to 6 mpg better fuel economy, it was dramatically faster and it sounded way better.
I've since installed a 408 Magnum with ported Eddie's, a healthy hydraulic roller cam and hooked it to an Extreme Automatic's Stage 2 200R4 with a 3800 rpm lock-up torque converter and 3.90 gears. The car is like Dr Jekyll & Mr Hyde. gets 14 mpg around town, 17+ at 70 mph on the freeway and beat 2 Hellcats in the drag races at Willow Springs a few years back.
I will never go back to a slant.
"Most of his speed secrets" my big old BUTT. I had a 65 225 Valiant years ago stone stock I raced for the hell of it that ran in the17s. Dutra saw you comin. Jes sayin. I can make a slant run 14s real quick like in a early A body and I probably will before the big block swap.
Dutra is a legend in the Slant 6 community and deservedly so. His Comp Cam profiles spec's, Dutra Duals and love and contributions to the Slant 6 community are are well documented on Slant 6.org, as is his willingness to help fellow Slant 6 owners.
Not sure if you are insinuating he ripped me off somehow, but I can assure you Doug Dutra is a knowledgeable, widely recognized fixture in the Slant 6 community.
I sold that motor for $2500 after driving it daily for 2 years. I pulled it to put in an EFI'd 5.9 Magnum. I had 10 calls for it in 2 days, so, yeah, I am sure glad he saw me coming. Thanks for the response, Rustyratrod. Doug deserves more recognition than he gets.
Rusty, A better photo of the throttle bracket you asked about.
