dell is it me??????
godfatherofchry
Legandary Member
Legendary Member
sabillasville md.
im new to this computer thing but any ways...this thing has been truble sinse day one.it kept shuting off evry time you try to do something on it.So finely it just died.And after three hours on the phone dell says the hardrive has died and the thing that holds the disk is dead.So three day later a man comes and puts new stuff in it.man im thinking finally my comp.is up and running.SO here we go getting it all tuned in and the next day the dam thing shuts down arrrrrrrrrrr boy was I pisset or what im not even going to tell ya about the call to delll was like.or im shoure I would be band from the site.any ways here I im.the reson for telling you this is becuse it has shut of three times since saterday and I wanted to see if I could get this done before it shut down again and it hasent but im still going to call them in the A.M Has any one else had this problem....THANKS for reading.:angry7::angry7:
I had it happen sort of like that before. It turned out to be the power supply inside the computer going out. It would get hot and shut down. i hope the solve the issue for you. Dell is usually pretty good about it once you get to talk to someone here in the U.S.
mine did the same and i bought this power pack has never done it again
My Gateway had a similar problem. Kept shutting down. Sometimes it would shut down before it was through booting up. Ended up ruining the hard drive. Gateway said it needed an upgrade flash to the bios. Was fixed under warranty.
Gawd, I love wiring spaghetti!!!! Let me ask you this, by "shutting down", be more specific, verrrrry specific as to what it does. what is your operating system? is the system in an area of decent airflow? as someone else mentioned, are the fans working?
you can download a program called "speedfan" that monitors the temps on the motherboard for most systems, also looks @ your hard drives and can look @ the s.m.a.r.t. data from the disk and tell you the general health of the hard drive.
Is the system just powering off, or does it blue screen crash?? If blue screen, when you boot it up, look @ the event log with event viewer and see if there is anything in there that could be pointing to a failure.
Oh, here is the link to the download of speedfan:
http://www.almico.com/sfdownload.php
Just under the header "download" is a blue "speedfan 4.0" just click on that, download it, install it, and look @ your temp sensors and fan speeds.
Hope this helps
FF
well let me try this again yes the fan is working.its alap top (inspiron 1720) I yous this on a table with the back proped up 1 1/2 inchs.im going to get of before this shuts off again.......i will be on the phone with dell around 9 this morning..
I know very little about laptops . I wonder if there is a battery saver setting at play ?
..love my dells..beyond fantastic tech support...spent 20 years in the IT biz..
Grassy
I'm instantly reminded of the dad plugging in his new Leg Lamp Award in A Christmas Story ... zzzzzzzzzzzzzzzzt
godfather, I won't be any help with your problem but did want to say I enjoyed our phone call the other morning. It was great to talk with you!
Good luck with the crisis. These guys will help you get through it.
If I have my laptop on for more than 5 hours it starts acting funny and frezing up. If it is colder out I can stay on longer.
If you are in a dusty environment or have pets the laptop's ventilation can get clogged causing it to overheat and shutdown. If the service tech did not replace the thermal grease when he reassembled it, this can cause this also cause this to happen.
Dell is pretty good with thier teck support. Most seem to be India though.Sometimes real hard to understand,allthough I did get one gentleman who was educated in Caimbridge and had an indian/english accent.
One word about Dell printers.
DONT buy one! You CANNOT get ink anywhere but Dell for them and it's a total rip off!
Dells are good when they are running but when warranty is out their teck support
sucks, even if you pay for it. If I were you I would buy a extended warranty if I
bought one
Everyone running a laptop should be using a cooler. It plugs into a usb port and is just a thin plastic box with fans in it. It helps keep your laptop much cooler. My wife's laptop would also shut off if it got hot. this may or may not be your problem. Good luck.
