j par
Let me be the first to say....
Yep. The birth control guys get butt hurt easy.
Hey yellow rose-
how do you go about tuning your clutch, do you use a data logger?
Oh look, he started in with the name calling. Again. I'm not offended, you're simply just wrong in this case. All I did was point that out. I simply said, several times, that what you're suggesting is totally unnecessary. Ok, I called it lunacy. But spending $2k on a clutch for a 200 hp car is lunacy. Your set up probably works great for a 9 second drag car. Your incredible knowledge of clutch tuning may even allow you to run it with ease on the street, even if I think you're stretching the truth on that since you're so unwilling to explain how it is you actually manage that. Regardless, there's no reason to use one in this instance. None. And you've given no evidence or proof to show otherwise, just the usual ill will and name calling.
If you were truly an expert you would know that recommending a $2k clutch when a $300 one will do is in fact lunacy. No different than recommending a $300 clutch when a $2k clutch is needed, it shows the same lack of knowledge. Clutch tuning is a great skill to have, but unfortunately 90% of the people on this board have absolutely no need for it whatsoever because they can run off the shelf "junk" that will last the life of their cars trouble free without having to do any tuning at all. Anything more is just a waste of money and time for a vast majority of cases.
Good luck. Many people, myself included, have legitimately asked yellow rose to explain his process and set up in multiple other threads, so that they might actually try and learn from his supposed immense knowledge. He's never explained, he typically gets defensive like he has here already and basically just keeps saying that if the rest of us knew what he knows we'd all run the same thing as him. Of course, he's never actually said what he runs beyond saying it has a sintered iron disk and a Long/B&B cover, so, it would be difficult to know even if someone was running the same set up as him.
Based on your wonderful explanation of modern diaphragm clutches earlier in this thread, I'd be willing to bet you have nothing to learn here, even if yellow rose is truly the expert he claims to be.
I data log weed burner. But I disagree with about 98% of what you say. Not a fan of using screen door parts to control a clutch you can't adjust. And it's not just me that thinks that. Never seen a Comp guy use screen door parts. Never seen a stocker or super stocker use that crap either. Don't be offended. We just disagree.
YR you sucked me in to replying to this thread thou I told myself you weren't going to do. There are people that have a library of knowledge but make lousy teachers cause they don't have the ability to convey what they know. Then their are those arm chair quarterbacks that spout off numbers and claim of vast knowledge that really don't know ****. I don't which you are,nor do I care. You are obnoxious, keyboard bully that live to agitate others. You did it to me,RRR and others in previous posts. I'm done putting up with your BS. That is why I love the ignore button.
Their is a WORLD of difference between counterweight locking up a clutch, and screen door parts letting a clutch slip.
Diaphragm clutches are inferior, period.
Fine for a grocery getter, but have no place in a competition car.
If you've ever had one hang open during a 7 grand powershift...or have the fingers go limp, out of the blue, because of heat and fatigue, you know the pain.
That difference is more area under the rpm curve for screen door part control of clamp pressure vs centrifugal application of clamp pressure. It's the same reason the TF/FC guys use timers to limit centrifugal assist at the throwout bearing early in the run. The advantage is basically that controlled slipping of the clutch nets a higher average rpm, which allows the engine to produce more power strokes over the duration of the run...more area under the rpm trace.
Centrifugal control of clamp pressure forces you to start below the clutch's lockup rpm and "drive into it" to be effective. That's where SoftLoc gets it's name. What they don't tell you is that after you launch, that centrifugal application of clamp pressure after the shifts is anything but soft. Just look at your rpm traces after you make a WOT shift- that SoftLoc locks up so hard that it jerks your rpm almost straight down, until rpm is pulled down far enough for the clutch to start slipping again. The screen door parts method does not add clamp pressure with rpm, so the clutch can begin meaningful slipping after a WOT shift as soon as you pull your foot off the clutch pedal. The result is that rpm drop after the shift is more diagonal on the graph, which adds area under the rpm trace.
NMRA classes such as Coyote Stock are required to use spec crate engines, spec transmission & ratios, and diaphragm PP's, an attempt to keep the playing field more level between the haves and the have nots. Ace came out with a centrifugal assist diaphragm PP which is legal there, but skirts the intent of those cost control rules. Guys that stepped up were used to shimming their diaphragm PP's nearly every run to keep clamp load in it's sweet spot. Centrifugal assist looked like a way to greatly reduce clutch maintenance, didn't take them long to figure out that centrifugal assist lowered their average rpm vs shimming.
It is 100% about the controlled application of the clutch.
There was also some bullshit about coil springs losing clamping load faster that a diaphram. That is wrong. ANY spring is subject to load loss. Mostly from heat. A diaphram is not immune to this, or any better. So keep slipping your clutch, eating up discs and wasting your time.
They sell you a diaphram because it's cheaper to make. The manufacturer makes more profit for unit sold. Simple as that.
Yeah, see what you started! lolWell I had no idea what was going to transpire when i asked my question. Lol.
If you really had control over it, would you still want your SoftLoc hit so hard after the shift?
It was about coils losing clamp load at a faster rate as the disc wears thinner. Might want to read up on the characteristics of a belleville spring.
So you're thinking there's more profit in a cheap diaphragm than in a $1200 SoftLoc?
Damn you are hard headed, but I keep in mind you are trying to sell something.
1). If you can't get the plate pressure down at the shift, you are doing it wrong. If you have the CW correct, you won't see the RPM drop, but the clutch won't be locked up. It can't be.
How do you get the plate pressure down at the shift when the engine is at it's maximum rpm and your foot is flat on the floor?
You rely too much on CW. It's the new "in" thing. Use less counter. More base. As the pedal comes out it should pull the engine down, or you are slipping the clutch.
What is the benefit of any counter at all unless you are clutchless?[/QUOTE
Really? You can use a little less base with some CW. If the track is good I up the base a bit. If it's crap I pull base out. Once I sort out the CW I almost never adjust it. Unless I have to change shift RPM. Or if I make a big move on the 2 step.
Let me be the first to say....![]()
