Diff ratio help
LionelR
Australia
I don't know exactly what ratio diff to get for good, all-round general driving and economy for my A body Australian Charger. I have 650hp Gen 3 hemi with close ratio six speed Tremec Magnum, 18 x 40 x 315 tyres - no drag racing, driver mostly, fair bit of highway. I'm thinking something like 3.08. Thoughts?
I think 3.08 is a good compromise. No ratio is ever perfect.
i know that there's a few flavors of these boxes in regards to 1st gears and which OD gear, so i'd say pick one that will be most usable in OD and compliments the gear spread the best.
with the power you have the starter gear is a really a non-issue, and i'd guess you'd have trouble not totally just blowing the tires off in first or second.
running some quick starter and final drive numbers, i'd probably pick something in the 3.7~3.9 range
souns like a cool projects, let's see some pics!
Something in the lines of the last 2 posters. 3:08 is too tall with the transmission you have. 6th gear would be useless until 100mph.
It's still a old original, untouched car at present. I'm just collecting all the pieces I want for when I find time to put it together. Got a 448 Hemi coming from Better Built Performance, 650hp, 610ft/lb - great guys to deal with! - the tremec six speed from American, and now sorting diff and rear suspension, wheels, tyres, etc. Car came with 14 inch wheels, 70 series tyres x six inch wide. I'll be going 17 inch wheels, with 45 series or 18 inch 40 series and hoping to get 12-14 inch wide at rear 8.5 inch wide tyres at front.
That trans, if I found the right data, is essentially a four speed with a double overdrive. 5th gear is .74/.80 and 6th is .60/.50, depending on the version. With that 6th gear ratio you can run a pretty steep diff gear and still have very reasonable rpm range at typical highway speeds. I would go with something in the 3.91 - 4.56 range. You may also need to consider the cam that comes in that engine and what rpm range it is making power. There are online calculators that you can put all your data in and figure out a good compromise. I wouldn't think that motor would be overly happy lugging down the highway at 1500 rpm which would be about where you'd be with a 3.08.
No kiddin. I caint believe anyone would ever agree with that! A transmission with TWO over drives and a 28" tall tire with a 3.08 gear. Have at it! No way I'd run anything numerically lower than a 3.91. That would be an absolute minimum. I'd be leaning more toward a 4.10, 4.30 or even a 4.56.
He's asking about economy, so setting up 6th to be at rpm with enough torque that it can maintain highway speed, not pull hard from that speed without a down shift.
Just remember that when you head down into the 4.1/ lower you are starting to generate heat in the differential, and higher, MUCH higher drive shaft RPM, so balance and design becomes a real issue
What is first gear ratio
What is the OD ratio(s)
How tall are the rear tyres in inches?
What is the HP and torque curve of the engine (RPM) don't want to ride the clutch to get it moving,
Won't do any good to be too low in rpm, kills the power and economy.
650 horse power and you are searching economy?
2.92 first gear, 0.8 5th gear, 0.63 6th gear. Rear tyres are 26 inches, haven't got dyno results yet and I don't want stupidly low revs on the highway - about 2000 - 2100 at 65mph is about it. With 650 horses, 5th gear is a power gear at 65mph if I want to overtake, but I love 4th for doing it in a quarter of the time. Sixrh gear is just a waste of a gear, unless you want to save on gas travelling freeways. I'm happy to use the gears, it's why I got it, so good cruising RPM at 65mph is what I'd like. Sounds like 3.7 to 3.9 would be much better suited to my needs? 3.9 more so?
4.30 + and use it as a 5 speed except for stump pulling.
Hang on fellas;
As to fuel Economy;
1) If that engine has a factory computer controlled EFI/Timing, then run whatever rear end ratio that computer was tuned for.
2) If that engine has a stand-alone EFI/Timing computer, well yur in for a treat tuning that for 3.07s.
3a) If that engine has a carb, AND mechanical distributor, and has long-tube headers; I foresee lotsa problems.
3b) To get as much power as you say your engine has, IDK the cam size/Dynamic compression ratio/ nor the cylinder pressure, cuz I don't run in those circles......
But I can tell you this, from my fairly extensive modest-cam experience;
So from here to the end of my post, this is all from my experience, and I get that nunuvit may apply to your application. It's OK, I'm retired, so how much typing I do, is not up to Rusty.
For a modicum of hiway fuel economy,
1) as to Power stroke; the cam should have more than about 104*. This is already too low for my liking. It doesn't get much better until 110* . And, honestly, 114* is where I'd like to be.
2) As to overlap; by the time it gets to ~60*, the headers, at low-rpm, are pulling fuel charge right across the top of the piston and out the back door it goes. By 76*, you better have the timing figured out, or you'll be leaving a trail of stink in your wake.
3) As to cylinder Pressure, the more the better, until you get into detonation.
4) As to intake and Exhaust durations, you get whatever is left over. If the engine doesn't make enough power on the leftovers, get a bigger engine, or supercharge it.
As an example;
say you had a cam with 108* Powerstroke, 120* compression; that totals 228* . The total available is 720 plus say 76* overlap=796. So then, that leaves 568* for Intake plus exhaust; so say 284/284, or 280/288. On a fast rate of lift FTH cam that might be 240/240@050. That's getting to be pretty big for a Manual trans car.
5) What I figured out for my COMBO (see Avatar) was to run the hiway rpm at just above the rpm that generated the highest no-load vacuum, at the highest possible ignition timing.
This is the lowest rpm that the engine first becomes fuel efficient.
Any lower, and
a) some of the fuel-charge is going right out the exhaust, b) or the Short Power-Stroke is blowing wasted energy right out the tailpipes. Once the engine is built, you cannot do much about the PowerStroke except degree the cam to maximize that.
Any more than this, and
a) the rpm is multiplying all the shortcomings of the combo. and
b) yur just wearing out your engine for no good reason.
6) to that end, I developed an easy test.
I mean it's so simple.
Install a vacuum gauge and SLOWLY, rev the engine up, until the vacuum plateaus, then, increase/decrease the timing until the engine looses rpm, then reduce the rpm say 500 and again slowly bring the Rs up, until the rpm again plateaus, and again adjust the timing for highest rpm.
Record the Timing and Rpm.
My engine has had three different cams, and on each camchange, I changed the compression ratio, to arrive at or near the previous pressure. So, when I did this, the vacuum plateaued;
....~2400 with the 292/292/108 cam,
to ~2000 with the 276/286/110 cam,
to ~1800 with the 270/276/110 cam.
In each case, I initially geared the car to those minimum rpms, using a combination of rear gears and transmission gears.
Some combinations had 8 useable progressive gears, some had 7, and I now have 5, cuz that's all my 367 needs. Eight or even Seven was just too much.
Now, That method above, establishes the ideal rpms.
Sometimes, I imagine, the minimum rpm might be rather high. Say your minimum turns out to be 2600, but you want to cruise at 1800. The logic argument is that as the rpm goes down, fuel economy goes up, and that is true for a small-cammed engine , like a factory 318, that vacuum plateaus just off idle, lol.
But say you have established that yours Plateaus at 2600. That is where it will get best fuel economy, jus saying. If you cruise at a lower rpm but same speed, that engine will lose fuel efficiency, but gain economy from the lower rpm.
I proved this once by gearing my 270-cammed combo down to 65=1600rpm in double-over, which came to either 2040 or 2240 in one of the other two selectable First-overs, (Gear Vender, or A833 over) on an 1800rpm plateau . Thus, cruising at either 1600 or at 2040, economy was about the same cuz neither was at the 1800 ideal. But cruising at 75=1800 was, and again, the increased speed cost me what engine efficiency gained.
So that was Problem #1, hiway rpm
Now, about problem #2; how slow do you want to go?
1) Do you need to drive slowly? If so, what is the lowest rpm that your engine can comfortably idle at? You use those numbers together with the tire height, and your minimum roadspeed to calculate your starter gear.
Your tires are about 28 tall.
You may want to parade at 4 mph.
Say your engine idles at 950rpm
Say your trans has a low gear of 2.87.
Doing the Calculation, spits out a Rear gear of 6.89.
That's a Problem;
this car will NEVER parade with people walking.
Lets say you did install those 3.08s. Your minimum roadspeed would be ~9mph, so I mean, that's even fast when pulling thru a drivethru. Yur gonna be toeing the clutch a lot. And your Hi-Perf clutch is gonna have to deal with that.
But say you get the Idle-rpm down to 780;
and run 4.88s;
Now you can drive at a minimum roadspeed of 4.64mph.
But say you got the Wide-ratio trans with a 3.27 low, and still with the 4.88s, Now you can Idle down the road at 4.1mph, still too fast for parading, but acceptable to idle around at carshows.
Lets work the Formula in reverse; with the 2.87 low, and 4.30s what would the Idle-speed need to be, to drive at 3.5mph?
Answer 518rpm. It'd never gonna happen is it......
And with the 3.27 low?
Answer, 590rpm. Still not realistic for an engine of your caliber. If this matters to you, then you kindof need a 2-speed rear-end like a Quickchange.
Ok so that solves those two problems
Problem #3 is this.
In my experience as a streeter; 65 mph is all I wanted to hit, and the only way to get there quick, was in Second gear. If I got into 3rd, the car lost ET. If I tried to get there in First, the rpm went outta sight. So second it was. So I geared it to to just run out of pulling power at 65. Of course that required a different Pumpkin for each cam.
My favorite cam was the little 270* cam, which made up to 195 psi cylinder pressure, so she was no slouch in those first two gears. The PowerPeak was around 5200, but with the Edelbrock heads, she kept pulling a looooog way beyond that. So I installed 4.30s, which got me 6000= 62mph.
Of all the combos that car went thru, this was my favorite.
If you run the close ratio trans, I think Second is 1.89 to my 1.92, so you'll want a similar rear gear, namely the 4.30s. Which will idle at 5.28 mph@780 rpm, in 2.87 low gear..
So again, you need a two-speed rear gear, to solve all three problems so far. Or, an automatic transmission.
(And that's why I pulled the 292 cam outta my Combo. They told me that cam was too big for street, but nobody could tell me why, definitively. I tried ALL SUMMER to make that cam work, cuz at 7000 that thing was still a beast! I pulled it out...... cuz NO-WAY was I gonna put an automatic on that engine. )
There's no sense in me suggesting what rear gear to run, cuz I don't know what's most important to you; and In your case NO RATIO is gonna cover all driving conditions.
About the closest you might get is;
1) at the bottom; the Idle-Speed will be too high for walking speed, no matter what the rear gear is. With 4.30s the minimum Roadspeed is about 5.27@780rpm.(2.87 low)
2) on the street with 4.30s and 28" tires, in 1.89 Second Gear; 65=6330.
3) to cruise at 65=2200, requires a Final-Drive Ratio of 2.82. With 4.30s, that would require an overdrive of .66
Nice car!
