Diffrence between 426 hemi and 426 hemi RB
I will get some pics of it as soon as I find my Camera. I set it down in one of the sheds or trailers and its gone. The search has been going on for a while. Once I have pics you can let me know.
Do you have any plans for that block OMM? How do the main webs look compared to a 440? What did the block come on or was it a Mopar Performance piece?
I ask because I am wandering into 528 drag race land...
Chrysler Illustration,
1962 413.......Everyone wants an 'RB' 413
th
If they are not Hemi's they are wedges. 273-360's and 383-440's It was just a name to promote performance sales. 340 wedge, 413 wedge, 426 wedge. They were stickers is all. They are all the same. A 70 340 is no different then a 71 340 wedge. And so on. A Max Wedge is no different then a Ram Charger.
Was there a 426 wedge??
Okay....here's my take on the difference between an original 426 Hemi and a "RB Hemi".......
An original 426 Hemi is indeed a "raised block"....as far as the distance between the center line of the crankshaft and the surface of the deck. An ORIGINAL 426 Hemi also has the cross-drilled main caps which make it a special block.
A "RB Hemi" is a 413, 426, or 440 "RB" block with a hemi-head conversion. This particular set-up does NOT have the cross-drilled main caps. It would have the standard two bolt main caps.
This pic is of the cross-drilled/bolted main caps for a hemi motor.....
............. They were stickers is all................ They are all the same. A Max Wedge is no different then a Ram Charger.
I realize what you are trying to say, but part of your statement might mislead people. A "max wedge" is hardly a "sticker is all"
There was a discussion on a board the other day about an alleged "maxi" (no photos, OF COURSE) and it became clear that some people don't seem to know what a "max" wedge actually IS. I know YOU know this, but a max is about as "the same" as an everyday wedge as a "boss" is close to a 302 2bbl
Not quite true. Chrysler PER SE only made the 331, 354 and 392
Dodge and Desoto had "their own" hemi engines, which were in some ways quite different. The Dodge design was based on the early A Poly block
My reference to Chrysler meant all brands from Chrysler including Dodge and DeSoto.
anybody heard of the 440 ball-stud hemi developed and never made it to production.
426 hemi is a RB engine.
Yeah Fishmen,I have.Mopar trying to lower costs,to.use the newer technology.Used a non adjustable valvetrain,like a 429/460 Ford.Mopar Action ran a article,a decade or so ago.
I guess what makes a 426 hemi block is casting numbers. Didnt hemi blocks have 1/2 inch pickups though?
cross drilled crankshaft......main caps arent drilled......correct me if i'm wrong
the a 999 had some issues and then the idea got scrapped before it came into play about when the hemi got banned for nascar was gonna be a bad boy too:(
stage V hemi conversion heads are more expensive than MP crate Hemi heads now, pretty much dried that market out fast. I think speed shops are making 426 hemis out of gen 3's now with stroked cranks.
1959
Introduction of the 383 'Raised Block" and 413 Wedge
Yeah Baby !!!!!!1
I have a particular affection for that issue of Hot Rod Magazine.
My dad has a large write up on his 1959 Plymouth in that issue. It's titled:
"Hot Prospect: Plymouth's new 361" Bill LaRoy suprises the best competition with an engine they said "wouldn't run"---the wedged-chambered Plymouth V8.
The car set a record at Bonneville in 1959, when it ran a two way average of 150.251 MPH.
Plymouth introduces the 1959 383 'Raised Block'
November 1958 Hot Road Magazine
Bonneville Speed Trials
[ame="http://www.amazon.com/gp/product/images/B005TM3BFA/ref=dp_image_z_0?ie=UTF8&n=283155&s=books"]
[/ame]
FWIW, Pro Stock racers John Hagen and Charlie Malyuke developed and ran low deck Hemis in Pro Stock and even set a record! Don't recall if they used 383 or 400 blocks and don't recall the finished cubic inches, but I believe they were in the 366-394" range. Lots of work, but cool stuff .Got the info somewhere but don't have time to search.
