Dipstick tube hitting??
Small Block Mopar Engine
  1. BWDart
    BWDart FABO Gold Member FABO Gold Member
    1,314
    373
    May 25, 2005
    New Braunfels TX
    Local Time:
    11:34 AM
    Put a new tube and stick in the la 360 small block,the stick is hittin something[windage tray?] It goes about 3/4 of the way in so it's in the pan which is stock. It's a chrome replacement don't know why it would be hittin. Any suggestions?
    Thanks
  2. 73smallblock
    73smallblock Well-Known Member
    82
    38
    Nov 4, 2015
    PA
    Local Time:
    12:34 PM
    Try spinning the dipstick 180*. Mine hits the windage tray if I put the slot in the handle facing the grill, flip it 180 so it's facing the firewall and it's fine. I am using a milidon windage tray/pan and a Mopar chrome dipstick
    • Like Like x 1
    • BWDart
      1,314
      373
      May 25, 2005
      New Braunfels TX
      Local Time:
      11:34 AM
      Thanks I'll try that
    • Syleng1
      Syleng1 Karma is real and Life is short... FABO Gold Member
      1,917
      1488
      Jul 5, 2005
      North Franklin, CT
      Local Time:
      12:34 PM
      Are you sure its the correct length?
      I've had to cut down a tube or stick to adjust. Is your bottoming out on the pan floor?
    • BWDart
      1,314
      373
      May 25, 2005
      New Braunfels TX
      Local Time:
      11:34 AM
      It's hittin really solid and yes it's really long compared to the stock one I'm gonna get the stock stick and cut the tube to match I still have the old tube to use for measurement
    • pishta
      pishta I know I'm right....
      18,611
      8087
      Oct 13, 2004
      Tustin, CA
      Local Time:
      9:34 AM
      Someone with a pan off should measure how far the stock dipstick drops below the pan rail for reference. Iirc the trans dipstick only pokes 1/4" past the rail.
    • nm9stheham
      nm9stheham Well-Known Member
      12,090
      3943
      Dec 20, 2013
      Waynesboro, VA
      Local Time:
      12:34 PM
      Just a word of caution: There have been a few cases reported here (including pix) of the dipstick getting caught by the crank and a piece broken off and wrapped up in the crank.
    • cudamark
      cudamark FABO Gold Member FABO Gold Member
      7,402
      590
      Mar 14, 2009
      San Diego
      Local Time:
      9:34 AM
      That was a real common slant 6 problem. Sometimes you need to put a slight bow or bend in the dipstick tube to make the dipstick clear obstructions.
