By 1974, Chrysler had removed the bushing replacement procedure from the service manuals, and specified housing replacement if the bushings were worn beyond specifications. Later electronic distributors did not wear as much as point distributors due to having no shaft contact as there was with the cam and rubbing block of points. The earlier manuals had the procedure. It is for point distributors but the housing bushing replacement is the same as electronic after the distributor is disassembled. The procedure does involve special tools.
Following are the pages from a 1966 service manuals with the procedure:
I've replaced them a couple of times over 30 years ago without using the factory special tools, but I have not needed to replace any in a long time. I just used a drift, some spacers and a press. I was concerned about the lack of burnishing tools, but I got away without using it.
