canadian duster
Hi all,
I am finally within striking distancing of breaking in my 408. I'm looking for guidance on the initial timing setup and distributor install. From reading older posts, my manuals and hopefully common sense this is my plan, and just wanting to make sure i have no holes in this.
- TDC is marked on dampener (checked with the rotor slot alignment on the distributor gear and TDC tool in sparkplug port)
- since i'm running a blower on this unit, i have a locked out MDS distributor and plan to run 28* timing (initial & total) based on recommendations from similar builds
- to accomplish this i was planning these steps:
- install distributor with slot pointing at front driver intake bolt with engine at TDC
- rotate crank CCW to 28* timing mark
- adjust distributor back to having the rotor point at the intake bolt again
