G Gimike812 Well-Known Member Joined May 27, 2015 Messages 52 Reaction score 14 Location Tucson AZ Mar 1, 2020 #1 Can this plastic piece at the bottom of the distributor be replaced? If so where can I find one?
Mattax Just the facts, ma'am FABO Gold Member Joined Feb 7, 2013 Messages 17,805 Reaction score 14,805 Location Phila. Pa Mar 1, 2020 #2 Yes. Drive the pin and put another on.
MoparMike1974 FABO Gold Member FABO Gold Member Joined Jun 16, 2017 Messages 4,573 Reaction score 4,372 Location Maryland Mar 1, 2020 #3 Last one I replaced I machined out of delrin.
Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 14,912 Reaction score 12,274 Location Northern Colorado Mar 1, 2020 #4 Someone on FABO was selling a metal machined replacement. Last edited by a moderator: Mar 1, 2020
Demonic Well-Known Member Joined Mar 21, 2015 Messages 2,320 Reaction score 2,113 Location Mid Atlantic Mar 1, 2020 #5 @halifaxhops
toolmanmike Moderator Staff member FABO Gold Member Joined Jan 18, 2006 Messages 83,924 Reaction score 94,412 Location Office Mar 1, 2020 #6 Demonic said: @halifaxhops Click to expand... Yep. @halifaxhops is the guy that can help.
mbaird mbaird Joined Dec 10, 2005 Messages 9,341 Reaction score 6,555 Location Boise, Id Mar 1, 2020 #7 I found a brass bushing at the hardware store that fit perfectly ! I just had to drill the roll pin holes .
halifaxhops It's going to get stupid around here! FABO Gold Member Joined Jan 20, 2014 Messages 87,025 Reaction score 67,318 Location Hoppyworld, PA Mar 2, 2020 #8 Whatever you do do not use those big shaft collars with a set screw, they limit the oil from getting into the bottom of the distributor and you will be changing bushings. I have some shoot me a PM if you need a set.
