rva
HI putting a 340 in a 64 barracuda 4 speed that I just picked up, will the 68-70 340 hp exhaust manifolds fit, I'm sure there will be some z bar mods but over all, or do I need the 273 manifolds.
Thanks I will readThis may help. I'm sure there are other threads about it. 340 Exhaust Manifolds on Early A-Body??
ok, I have manual brakes and steeringThey fit, might have to trim the collar a bit on the column. Manual steering only, won't fit power.
I just looked on TTI's site. No head pipes for those manifolds in that car. Too bad. They do a nice job with that kind of stuff.
I checked, they don't. Keep us posted how close the Duster pipes are. You may be onto something.I have a set of head pipes and tail pipes for a 70 duster with the hp manifolds, hope I can make them work, also I will check with accurate exhaust see if they make the head pipes thanks for all the help
hopefully soon, engine still in machine shop getting built but for sure will let you know.I checked, they don't. Keep us posted how close the Duster pipes are. You may be onto something.
It might not hurt to contact TTI and Accurite just in case they have something going. You know, they are just like a good exhaust shop. They make a pipe that works and then copy it X 100.hopefully soon, engine still in machine shop getting built but for sure will let you know.
and the 340 HP's
yep, thanks for the help, we will see when the engine gets here, I still have body work and paint just trying to get ahead of the game
I have TTI's now, but ran 68-70 340 hi-po manifolds in my 65 Barracuda for years. Here's my experience:
Passenger side: 71 and later manifold with center outlet fits well. In fact, with that manifold you can run a factory 71 Duster exhaust pipe as is except for adding one inch or so above the steering linkage. 68-70 manifolds, on the other hand, barely clear the inner fender. In fact, given factory variations, they may not clear in some cars. I had to dink the bulge over the rear upper control arm bushing and it still had barely 1/4 inch clearance. Down pipe will have to be custom made, but it's fairly straight forward.
Driver's side: With manual steering, the manifold will probably rub against the steering joint whenever the motor torques over (at least, it did on my car; again factory variations could give you a different result). Originally I cut the manifold in that area, turned the outlet around 180 degrees and rewelded it. Worked for a long time, but eventually broke at the weld. Got another manifold, trimmed the top of the steering joint housing and left the cap off and all cleared. Finally, I switched to a power steering column and used a Firm Feel adapter to mate it to the manual steering gearbox. Because the power steering shaft is shorter, this moved the joint out of the way. With all of these setups, the only place to run a 2.25" pipe was down between the torsion bar and the frame and then back. There was one spot where there was sufficient room to do that and still leave room for any motor rocking.
I can tell you that making 340 manifolds fit was a lot easier than making TTI's fit (although they eventually did, once I moved a bunch of stuff out of the way). But the TTI's make more power.
