do i need a cooling system resovior ?
Heating / Cooling / AC
  1. gashaller
    gashaller Member
    21
    0
    Apr 26, 2010
    cookeville tn.
    Local Time:
    9:59 PM
    Have a 1971 dart swinger, 318 have been having cooling issues put a campion 4 row aluminum rad in helped only a little.have not been running a resivior for rad. guy today said that is why I'm overheating, will that make a difference ?
  2. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack FABO Gold Member
    49,172
    15376
    Jun 7, 2010
    Georgia
    Local Time:
    10:59 PM
    Guy's an idiot. A reservoir, as it's spelled, will not make a car run hot, nor will it cure one. It is a good idea though, so you don't poison any stray animals.
    What's the rest of your cooling system consist of?
    • Agree Agree x 1
    • TrailBeast
      TrailBeast Slightly Twisted Member
      19,500
      5928
      Mar 11, 2011
      Arizona
      Local Time:
      7:59 PM
      All the reservoir does is allow the recovery of coolant pushed out while running, and it only does that as it cools down and causes a vacuum in the radiator.
      It makes zero difference in cooling while running.
      • Agree Agree x 1
      • fklskv
        fklskv Well-Known Member
        876
        374
        Aug 14, 2011
        Lackawanna, NY
        Local Time:
        10:59 PM
        Define your overheating. Running hotter then normal or puking coolant?
        If you fill a radiator to the top its going to push coolant out of the overfill until it finds its happy level. A coolant recovery collects the overfill then lets it back in when the coolant cools off. Benefits are twofold. It keeps coolant off the street and oxygen out of the cooling system
        • Agree Agree x 2
        • Yote
          Yote Well-Known Member
          1,166
          475
          Aug 30, 2015
          far eastern Colorado
          Local Time:
          8:59 PM
          Not an absolute necessity but probably a good idea. Older vehicles never had them but fluid level should be approximately an inch low, if not it will overflow and get there bu itself. Do you have a fan shroud and is your thermostat working properly. How about a thermostatic fan clutch, is it working?? If any of those , could be the problem with your heating.
          Yote
        • yellow rose
          yellow rose Doctor of Thinkology.
          15,551
          12117
          Jun 19, 2015
          Living on the razors edge
          Local Time:
          7:59 PM
          Make sure your pullies turn the water pump faster than crank speed.
          And a good two core will cool circles around a four core.
        • oldkimmer
          oldkimmer FABO Gold Member FABO Gold Member
          10,453
          1292
          Nov 11, 2006
          Kindersley, Saskatchewan,
          Local Time:
          9:59 PM
          U need a 195*t stat. A shroud and a decent fan. Kim
        • RedFish
          RedFish Well-Known Member
          23,053
          2002
          Sep 5, 2007
          Local Time:
          9:59 PM
          We should assume your new radiator has a new recovery type cap on it too. Adding that plastic bottle to my 67 is one of my best/favorite moves. At least 2 years since I last removed the radiator cap. A glance at that bottle tells all.
