doogievlg
Does it have a stock 360 cast crank in it now?
What's a rough safe max for HP and TQ for a stock 360 crank.
What are your goals?... HP, TQ, drivability
What are you constraints?...gas octane, gear, converter, drivability, idle, tune-ability
Cast crank. My goals are 500 hp, 550 ft lbs torque and still be able to hop it in and go on short road trips which means pump gas. If I went with stock stroke then 430 hp would be what I shoot for with the same drivability.
I already planned on changing the converter and I have a Holley Blue pump with new push lock hose sitting on the self if needed.
