Bonoz09
Many of you know i just picked up a new, a car full wight 70 duster, and have been working the bugs out for the past few weeks. Well took the car to the local chassis dyno (dynojet) and it laid down 295 rwhp/ 296 rwtq. They claimed they had a demon in with virtually the same set up as me and it was with 4 hp of my car. Just wondering what others with similar setups have made or what you'd think based on your experiences. So far you guys have been really helpful. Thanks again. i realize that the carb isnt optimal but looking for thoughts on it the way it is. Any guesses on a 1/4 e.t and mph given decent 60ft's(in my mind 1.8-1.9) are welcome
Mopar electronic ignition with Hi-Performance Coil
TTI nickel plated headers
TTI 2.5 in full dual exhaust
Dynomax Super Turbo Mufflers
904 street/strip transmission built by Klem Racing
Turbo Action 3500 rpm stall converter
3.91 8 3/4 rear
17 initial , 37 total in @ 2500 do you think its ok on pump ?? (this is what the shop set it at and said it should be fine)
340 .030 over (lower end built up by Best Machine)
KB243 .030 pistons 10.2 compression
Edelbrock Aluminum Heads 65CC
Edelbrock 1407 750 cfm carb
234/246 @.050 .540/.525 lift 112 lsa
Indy Adjustable Rockers
Edelbrock Performer RPM Intake
3.91 8 3/4 rear
