The dingus on the left (outboard) is an OSAC valve, "Orifice Spark Advance Control". Its job is to delay vacuum to the distributor for 7 to 17 seconds so the '73 cars could squeak past their Federal emissions type-approval tests and be legal for first sale. Notorious for causing hesitation, mushy acceleration, and poor driveability. You're best off leaving it disconnected; run the vacuum advance hose directly from the correct port on the carburetor to the distributor. The "CARB" stamp does not refer to the California Air Resources Board, it indicates which port originally got the hose from the carburetor.
The inboard dingus is a thermal vacuum switch. Its job was to block vacuum to the EGR valve below a certain ambient temperature. According to Chrysler, this was installed because at very low temperatures there was less tendency for high combustion chamber temperatures to form NOx, so under those conditions there was no need to suffer the driveability hit caused by EGR. According to EPA, that's a load of poo and this was really installed because the Federal emissions type-approval test protocol didn't include operation at the low temperatures when this dingus deactivated the EGR.
It was one of the first times EPA accused an automaker of installing an emissions control defeat device. Was it a bogus accusation? Maybe or not; that can only legitimately be answered by looking at emissions data with and without that dingus. It's academic at this point; if I were in your shoes I would permanently disable the EGR (remove valve and install blockoff plate with a new gasket is the neatest/cleanest way...or remove valve, flip it 180° and reinstall it with a new gasket…or leave the valve in place rightside up and just make sure no vacuum reaches it).
Since we are talking about making a Slant-6 Dart run better: find tune-up parts and technique suggestions in
this post. Do the
Fuel line mod and the
HEI upgrade . Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted
here for free download. And see
this thread.
