Drag Race Weather Station / ET Predictor
We use a hand held weather station all the time, especially for the weather conditions at various drag strips we race. The information is written in our logbook, that way we can refer back to it whenever we race there again. To us, it's a quite useful tool.
I have a Tag Command Air that has worked well. The more runs you log the better the et predictor will work.
My brother and I had one once. It seemend to work well. The more data you feed it the better it is. ALSO... We found out that you need to take your reading as close to the starting line as possible. Taking readings away from the line made it less accurate. Even a 100 feet away made a difference.
