j par
$1, 000 plus to get it set up, $33 per pass plus entry fees and gas to get there and back...
forget it...
I'm telling you this is what's taking me out of drag racing in the first place.. the all-out expanse.. that's why I over the last two years I've been transforming my car into something I can drive down to the track and a joy on the street more..????Your telling me you back tracking, on duel quad nos kit.
I'm sure it will.I'm only a half second off my old average and hoping the last thousand I spent on aluminum heads and a clutch Tamer will gain some of that back...
I really just race myself these days...I'm sure it will.
If I go an hour drive out to Woodburn which is a well prepped drag race only track (in the middle of nowhere typically in the Blazing heat with no where to hide from it) it cost $50 plus$10 at the beginning of the year for your number. You're supposed to get three practice passes but most of the time we get to then eliminations.. which for my 4 speed car against all automatics I only make it past the first round 1 out of 10 times which means three or four passes for $50 plus the hour drive each way..For each pro event we pay $150.00. And believe me once u run so fast u can’t go slower. Street is $45.00 and modified or whatever it’s called now is $100.00. Kim
If I can get it dialed in and much more consistent over this next summer then the following summer I might go back to racing hole in the hood again at Woodburn. But to go there and get eliminated in the first round against all automatic cars almost every time it just loses its luster quite quickly..I think your clutch tamer will out shine you new heads. not knocking your new heads(but it would be fun)
all seriousness, just like me going to 4200 stall converter, you leaving the line hard and then to keep pulling thru fist gear(after you get it dialed in at the track) is probably worth a half sec..........
With a cam that pull down low will probably add a lot of life to you clutch as well.
If nothing else it will make you more competitive and that's when it gets fun, bracket racing.
Yep that's me, but here's you..
I love opening up my car from a stop light.
I would like to get some "real" racing under my belt but the closet track it to far away so street racing it is for me....
My saving grace is my car is such a race car most folks have no idea what their in for. Who would expect a full on race car to be sitting at the stop light?
Its all about what we can afford and enjoy. Most days i jist cruze around at 25 MPH and that also makes me smile!
Don't make fun of Cyndi Lauper. She's a successfully recovered heroine addict. Also, have you ever heard her sing the blues? Get you a load.
