1. tony20110
    tony20110 Well-Known Member
    209
    14
    May 14, 2013
    Manassas Va
    Local Time:
    6:24 PM
    What is this “fuse box” connected to the firewall of my 66 barracuda termed? Thanks
  2. jazak5
    jazak5 Well-Known Member
    479
    135
    Aug 6, 2015
    NY
    Local Time:
    6:24 PM
    it's a "BULK HEAD" connector
    • Agree Agree x 1
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
      15,221
      4335
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      5:24 PM
      The mother of all electrical demons
      • Agree Agree x 2
      • Like Like x 1
      • TrailBeast
        TrailBeast Slightly Twisted Member
        19,328
        5730
        Mar 11, 2011
        Arizona
        Local Time:
        3:24 PM
        That mon frere is the bulkhead connector where all the wiring from the cabin to engine and vise versa pass through the firewall. (which in this case looks like it needs some help):D
        • Like Like x 1
        • tony20110
          209
          14
          May 14, 2013
          Manassas Va
          Local Time:
          6:24 PM
          Thanks y’all. It is a demon and it does need help. Good times.
          • Like Like x 1
          • j par
            j par Well-hung Member
            11,914
            4842
            Jul 2, 2014
            Portland Oregon
            Local Time:
            3:24 PM
            That was put there for ease of installation. I elected to unplug that and run my exterior wires under my drivers Fender concealed in a protective tubing.
            Unless you're trying to make it look like it came out of the factory then nevermind.
          • RustyRatRod
            RustyRatRod 30 Degrees Outta Whack FABO Gold Member
            48,400
            14296
            Jun 7, 2010
            Georgia
            Local Time:
            6:24 PM
            That's the biggest POS on Mopars besides the amp gauge wiring. If you want to make a tremendous upgrade, look at wiring harnesses by Ron Francis. They completely eliminate that bulk head connector and are very high quality.
            • Agree Agree x 1
            • Wagon of Death
              Wagon of Death Aussie Barracuda Fisherman
              64
              12
              Aug 30, 2009
              Brisbane,Aust
              Local Time:
              9:24 AM
              j par...did you just cut the connectors off, and extend the wiring to rejoin inside? This is on my to-do list and Im curious how folk get around it
              • Agree Agree x 1
              • tony20110
                209
                14
                May 14, 2013
                Manassas Va
                Local Time:
                6:24 PM
                Wish I had the money. That upgrade is gonna have to wait.
                • Agree Agree x 1
                • j par
                  11,914
                  4842
                  Jul 2, 2014
                  Portland Oregon
                  Local Time:
                  3:24 PM
                  I think it's a rediculous recommendation to buy wiring harnesses. I bought a spool of wire for $15.
                • j par
                  11,914
                  4842
                  Jul 2, 2014
                  Portland Oregon
                  Local Time:
                  3:24 PM
                  Yes
                • RustyRatRod
                  48,400
                  14296
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  6:24 PM
                  I can relate to that.
                • RustyRatRod
                  48,400
                  14296
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  6:24 PM
                  Some think it's equally ridiculous to use 50 plus year old original wiring. Wiring does have a life span. I'd much rather have a new, expensive wiring harness I saved up for than a pile of ashes in the driveway.
                  I found the wiring harness for my rat rod truck on Speedway Motors on clearance for like 119 dollars. No bulk head connector and 21 circuits. Total overkill for my project, but it was there, I needed one and it's NICE. You can find deals if you're not in a hurry.
                • j par
                  11,914
                  4842
                  Jul 2, 2014
                  Portland Oregon
                  Local Time:
                  3:24 PM
                  For a hobbyist which this is there only car and only project and not pulling the wiring harness out and stretching it all completely out on a piece of 4 by 8 plywood on two saw horses and rebuilding it. What kind of doubt you're going to take it all out and put it all back in. And you have tons of time and no money? Today or replace this wire and tomorrow I replace that wire and so on till it's done each wire individually is new and you know where it started and where it's going. All connections are changed or refurbished. take it off the pegboard and plug it in with complete knowledge of where all your wires go.:thumbsup:
                • Mattax
                  Mattax Just the facts, ma'am FABO Gold Member
                  5,221
                  2796
                  Feb 7, 2013
                  Phila. Pa
                  Local Time:
                  6:24 PM
                  Don't worry about it.
                  Clean it, check the terminals, and if you feel ambitious, remove each terminal and clean them properly. Reinstall.
                  Several threads here with photos and descriptions.
                  And if you drive alot at night, make a relay set up or buy one from screen name crackedback.
                  The fusebox is under the dash, near the left side vent door.
                  Headlights have a 15 amp circuit breaker in the switch.
                  • Agree Agree x 1
                  • Mattax
                    5,221
                    2796
                    Feb 7, 2013
                    Phila. Pa
                    Local Time:
                    6:24 PM
                    OTH, the wires through the sheet metal needs to be addressed as soon as possible.
                    Without the grommet, or something like it, it won't take much to cut through the wire insulation.
                    And the snipped wire (in circle) isn't much better.
                    Tape it. Find out what its for (get a '66 shop manual).
                    When you take the connector off, that terminal can be removed if you're not using, or replaced if putting back into service.
                    One more tip. Power is distributed in several places, not just the fusebox. The starter relay, the main junction, and then half the fuse box is hot from the main junction. The other half of the fuses are only hot when the key is switched to run or accessory.
                    • Like Like x 1
                    • Mattax
                      5,221
                      2796
                      Feb 7, 2013
                      Phila. Pa
                      Local Time:
                      6:24 PM
                      Here's one, except its a later year so the connector positions are not quite the same. Concept for disconnecting and cleaning is the same.
                      question on the main harness plug on firewall
                      Remeber some of those are connected to the main feeds so are hot all the time. Disconnect the battery before the connectors. Negative first.
                    • tony20110
                      209
                      14
                      May 14, 2013
                      Manassas Va
                      Local Time:
                      6:24 PM
